Harness specifications
Standardized Connections
The following represents the Autosport Labs standard power, CAN, and analog signaling standard for 2020 and on.
Connector Standard
Power + CAN
Single CAN interconnect
Dual CAN interconnect
Single analog/digital channel
Quad analog/digital channels
Available CAN bus cabling
CAN extension cables
| Orderable SKU | Description |
| ASL_M8_CAN_PATCH_1M | 1 meter CAN extension cable |
| ASL_M8_CAN_PATCH_2M | 2 meter CAN extension cable |
| ASL_M8_CAN_PATCH_3M | 3 meter CAN extension cable |
| ASL_M8_CAN_PATCH_4M | 4 meter CAN extension cable |
CAN Y-adapter
The CAN Y-adapter/splitter splits a single CAN bus so a device can be inserted within a loop. stub length to devices should be 300mm maximum, including length of Y adapter branch.
The Y adapter includes a 15cm feed connection with a M8 4P male connector, with two 1cm connections with M8 4P female connectors on each end, wired in parallel to the feed input.
| ASL_CAN_SPLITTER | Single channel CAN splitter |
M8 CAN + power pigtail
Used as a primary power + single CAN bus connection for a single wire setup.
| ASL_POWER_CAN_PIGTAIL_2M | Power + CAN pigtail, 2 meter |
Dual CAN interconnect (RJ45)
| ASL_DUAL_CAN_M8_1M | Dual CAN M8 6P male to M8 6P male, 1 meter |
| ASL_DUAL_CAN_RJ45_M8_1M | Dual CAN RJ45 to M8 6P male, 1 meter |
