Harness specifications
Revision as of 20:20, 14 September 2020 by Brentp (talk | contribs) (→Power + CAN)
Standardized Connections
Available cabling
CAN extension cables
Orderable SKU Description
ASL_M8_CAN_PATCH_1M 1 meter CAN extension cable
ASL_M8_CAN_PATCH_2M 2 meter CAN extension cable
ASL_M8_CAN_PATCH_3M 3 meter CAN extension cable
ASL_M8_CAN_PATCH_4M 4 meter CAN extension cable
CAN splitter
M8 CAN + power pigtail
Used as a primary power + single CAN bus connection to enable a one cable power + data solution.
Dual CAN interconnect (RJ45)
Inline CAN terminator
Analog/Digital cabling
Sensor Pigtail
Sensor Extension Cable
Connector Standard
Power/ CAN Single interconnect
Pin Connection Notes
1 CAN low twisted pair with CAN high
2 Power Red, 12v / 1A (12W)
3 CAN high twisted pair with CAN low
4 Ground Black
Single CAN interconnect
Single analog/digital channel
Quad analog/digital channels
Octo analog/digital channels
