Harness specifications
Revision as of 20:30, 14 September 2020 by Brentp (talk | contribs)
Standardized Connections
Available cabling
CAN extension cables
Orderable SKU Description
ASL_M8_CAN_PATCH_1M 1 meter CAN extension cable
ASL_M8_CAN_PATCH_2M 2 meter CAN extension cable
ASL_M8_CAN_PATCH_3M 3 meter CAN extension cable
ASL_M8_CAN_PATCH_4M 4 meter CAN extension cable
CAN splitter
M8 CAN + power pigtail
Used as a primary power + single CAN bus connection to enable a one cable power + data solution.
Dual CAN interconnect (RJ45)
Inline CAN terminator
Analog/Digital cabling
Sensor Pigtail
Sensor Extension Cable
Connector Standard
Power/ CAN Single interconnect
  • Connector: M8 4P
Pin Connection Notes
1 CAN low
2 Power Red, 12v / 1A (12W)
3 CAN high
4 Ground Black
  • Connector: M8 6P
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 12v
Single analog/digital channel
Quad analog/digital channels
  • Connector: M8 8P
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
4 Vref 5v @ 1A, combined with pin 6
5 Ground
6 Vref 5v @ 1A, combined with pin 4
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
