Harness specifications
Standardized Connections
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low
2 Power Red, 12-14v / 1A (~12W)
3 CAN high
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v @ 1A max current
Single analog/digital channel
  • Connector: M8 3P, A coding
1 Ground Brown
3 Power 5v @ 1A max
4 Signal
Quad analog/digital channels
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
  • Connector: M8 12P, A coding
1 Analog/Digital 1B
2 Analog/Digital 2B
3 Analog/Digital 4B
4 Analog/Digital 1A
5 Analog/Digital 2A
6 Vref 5v @ 1A
7 Analog/Digital 3A
8 Analog/Digital 4A
9 Analog/Digital 3B
10 Ground
11 Ground
12 Ground
Available cabling
CAN extension cables
Orderable SKU Description
CAN splitter
M8 Power + CAN pigtail
Pinout
Red / Pin 2: +12v Black / Pin 4: Ground White / Pin 1: CAN Low Green / Pin 3: CAN High
M8 Power + CAN device pigtail
Used to provide power + CAN to a CAN device such as AnalogX, TireX, etc. for a non plug and play installation, such as custom-wired application.
Dual CAN interconnect (RJ45)
Inline CAN terminator
Analog/Digital cabling
Sensor Pigtail
Sensor Extension Cable
Pinout
  • Red / Pin 4 : 5v reference
  • Brown / Pin 5 : Ground
  • Pink / Pin 6 : 5v reference
  • Green / Pin 8 : Ground
