Dual CAN Hub
Revision as of 23:49, 23 January 2021 by Brentp (talk | contribs) (Created page with " The Dual CAN hub expands two CAN bus networks into twin 4 expansion ports. 600px Power is provided through a single CAN + power i...")
Power is provided through a single CAN + power interconnect, which powers the connected data system (e.g. RaceCapture) in addition to devices connected the CAN hub ports.
Pinout
  • Supports two CAN bus networks
  • Input power + CAN connection for CAN1, suited for OBDII or ECU connection
  • contains 4 M8 CAN ports per network (8 ports total)
  • Includes 2 meter power + CAN pigtail
  • RaceCapture Integration cable available separately
  • Dimensions: 125x75x43mm
  • Weight: 200 grams
