TireX
High Performance
Rugged and Compact
Flexible Setup
Feature Description
Sensor type Thermal array
Accuracy 1C
Processing Engine 32 bit
Electrical
Interface CAN 2.0
Power 200mW
Physical / Environmental
Construction CNC aluminum
Dimensions 64 x 46 x 12.5mm
Weight 10 grams
IP rating IP65
Dimensions / Mounting
Mounting Distance
  • 205 width = 71mm
  • 225 width = 79mm
  • 235 width = 82mm
  • 245 width = 85mm
  • 255 width = 89mm
  • 275 width = 96mm
  • 315 width = 110mm
  • If only using 4 channels, you can mout 4x the distance
Electrical / CAN connection
Pin Connecton Wire Color
Pin 1 CAN Low Brown
Pin 3 CAN High Blue
Pin 4 Ground Black
Zone Configuration
Zones Coverage
CAN bus protocol
Formula
  • Example:
    • Formula: A / 100
    • Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
Value Symbol Reference
8 Bit values A
Default Main Base ID
Adjusting Main Base ID
Closed Closed 0xA100 (41216)
Closed Open 0xB100 (45312)
Open Closed 0xC100 (49408)
Open Open 0xD100 (53504)
Sensor Position Offset
0 Left-Front 0x0 (0)
1 Right-Front 0x100 (256)
2 Left-Rear 0x200 (512)
3 Right-Rear 0x300 (768)
Left-Front 0xA100
Right-Front 0xA200
Left-Rear 0xA300
Right-Rear 0xA400
CAN ID: Sensor Base ID + 0
3 Reserved
4 Reserved
CAN ID: Sensor Base ID + 2
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Preferences
CAN ID: Sensor Base ID + 3
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Calibration Preferences
CAN ID: Sensor Base ID + 4
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
Full Frame Mode
