Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
The plug and play Analog/Digital harness system lets you easily connect individual sensors to your RaceCapture system, without the need to splice, crimp, or heat shrink connections. Multiple-length extension cables for each stage of the harness lets you build a harness that perfectly matches your installation needs.
CAN bus harness components
Dual CAN splitter
Dual CAN interconnect
M8-6P male to M8-6P male link cable for connecting two CAN bus networks to our Powered Dual CAN Hub. 1 meter length. Product Info
Powered dual CAN hub
Powered CAN hub featuring 8 ports (4 ports for CAN1 and 4 ports for CAN2). Use with the Dual CAN interconnect cable to link to your RaceCapture or PodiumConnect system. Product Info]
CAN Extension
CAN splitter
Inline CAN terminator
Power CAN pigtail
Pin Color Connection
1 White CAN low
2 Red 9-24v / 1A (~12W)
3 Green CAN high
4 Black Ground
CAN+power for device
1 White CAN low
3 Green CAN high
4 Black Ground
8 channel extension
8 to 4 channel splitter
8 channel pigtail
  • 24 AWG
10 Grey Ground
11 Brown Ground
12 Black Ground
4 channel extension
4 channel pigtail
  • 24 AWG
1 White Analog/Digital 1
2 Yellow Analog/Digital 2
3 Grey Analog/Digital 4
4 Red 5v reference
5 Brown Ground
6 Pink 5v reference
7 Blue Analog/Digital 3
8 Green Ground
4 channel splitter
Single channel extension
Single channel pigtail
  • 24 AWG
1 Brown Ground
3 Blue 5v
4 Black Signal Input
Pressure sensor
Linear temperature sensor
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v / 1A (~12W)
Single analog/digital channel
  • Connector: M8 3P, A coding
1 Ground Brown
3 Power Blue (5v @ 1A max)
4 Signal Black
Quad analog/digital channels
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
  • Connector: M8 12P, A coding
6 Vref 5v @ 0.5A 5v @ 0.5A
10 Ground
11 Ground
12 Ground
