TireX
High Performance
Rugged and Compact
Flexible Setup
Quick Setup Guide
- RaceCapture system
- Powered CAN hub kit
Hardware Setup
TireX 4-corner plug and play harness
We recommend using the TireX 4-corner plug and play harness for the easiest installation.
By System
For newer plug and play RaceCapture and PodiumConnect systems
Using the Dual CAN hub
Get the 8 port hub and dual CAN link cable
https://www.autosportlabs.com/product/powered-8-port-dual-can-bus-hub-kit/
https://www.autosportlabs.com/product/racecapture-m8-to-dual-can-bus-link-cable/
Minimal installation using the Dual CAN splitter
For a minimal installation, use the Dual CAN splitter
https://www.autosportlabs.com/product/can1-can2-dual-can-splitter/
For older generation RaceCapture systems with RJ45 connector
Plug and Play option
Get the 8 port hub and dual CAN link cable -> RJ45
https://www.autosportlabs.com/product/racecapture-rj45-to-dual-can-bus-link-cable/
The cable plugs into the RJ45 port of your RaceCapture/Pro, and then plugs into the hub. Then, the TireX harness plugs into the hub.
Minimal installation (requires some custom wiring)
Get the Device CAN pigtail
https://www.autosportlabs.com/product/can-power-pigtail-for-device/
For other data systems
Get the Device CAN pigtail.
Provide power to the CAN hub
Software Setup
Enable the TireX CAN mapping
- Go to Setup/CAN mapping
Using the overview gauge
Using the raw channels view
| Feature | Description |
| Object temperature range | 0 - 127.5C (tire temperature mode (factory default)) / 0 - 255C (full frame mode) |
| Accuracy | 1C |
| Temperature zones (tire) | 1 / 2 / 4 (factory default) / 8 / 16 |
| Sample rate | 0.5 - 64Hz (Tire temperature mode, 16Hz factory default) 0.5 - 10Hz (Full frame mode) |
| Configurable positions | 4 (Left-Front (factory default), Right-Front, Left-Rear, Right-Rear); Reversible orientation |
| Electrical | |
| Interface | CAN 2.0 |
| Supply voltage | 6 - 14v (automotive power) |
| Power | 200mW |
| CAN bus | |
| Weight | 10 grams |
| IP rating | IP65 |
Dimensions / Mounting
Mounting Orientation
Mounting Distance
- 205 width = 71mm
- 225 width = 79mm
- 235 width = 82mm
- 245 width = 85mm
- 255 width = 89mm
- 275 width = 96mm
- 315 width = 110mm
Electrical / CAN connection
| Pin | Connecton | Wire Color |
| Pin 1 | CAN Low | Brown |
| Pin 2 | Voltage supply (6-14v) | White |
| Pin 3 | CAN High | Blue |
| Pin 4 | Ground | Black |
CAN termination
Customizing Termination
Zone Configuration
| Zones | Coverage |
CAN bus protocol
CAN protocol files
Formula
- Example:
- Formula: A / 100
- Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
| Value | Symbol Reference |
| 8 Bit values | A |
Default Main Base ID
Adjusting Main Base ID
Sensor Position Offset
| 0 | Left-Front | 0x0 (0) |
| Left-Front | 0xA100 |
| Right-Front | 0xA200 |
| Left-Rear | 0xA300 |
| Right-Rear | 0xA400 |
CAN ID: Sensor Base ID + 0
| 1 | Temperature Zones | unsigned | A * 1 | Number of configured temperature zones (1 / 2 / 4 / 8 / 16) (factory default is 4) |
| 3 | Reserved | |||
| 4 | Reserved | |||
CAN ID: Sensor Base ID + 2
| 1 | Reserved | |||
| 2 | Reserved | |||
| 3 | Reserved | |||
| 4 | Reserved | |||
Configuration Preferences
CAN ID: Sensor Base ID + 3
| 2 | Sensor Position | unsigned | A * 1 | Location of the sensor on the vehicle. This position adjusts the Sensor Base ID. Valid Positions 0 (Left-Front) / 1 (Right-Front) / 2 (Left-Rear) / 3 (Right-Rear). Specifying an invalid value will select the default value of 0 (Left-Front). Note: The sensor position affects the orientation of the sensor zones. Sensor Position 1 and 3 will report temperature zones left - right; Position 0 and 2 will report temperature zones right - left. Note: When in full frame mode, this setting is ignored. |
| 4 | Reserved | |||
| 5 | Reserved | |||
| 6 | Reserved | |||
| 7 | Reserved |
Calibration Preferences
CAN ID: Sensor Base ID + 4
| 1 | Ambient temperature compensation | unsigned | A * 1 | Value in C. Default is 2 |
| 2 | Sensor Resolution | unsigned | 16-19 | Sensor ADC resolution, in bits. Default is 18 |
| 3 | Reserved | |||
| 4 | Reserved | |||
| 5 | Reserved | |||
| 6 | Reserved | |||
| 7 | Reserved |
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
Full Frame Mode
