RaceCapture/Pro MK1 firmware upgrade
Save your configuration
===Download the Latest firmware version from Downloads section=== and unzip the archive to a location on your computer.
Windows
Flash the firmware by double-clicking the flashRCP.bat file in Windows Explorer and follow the instructions.
Linux
While holding down the button on RaceCapture/Pro, plug the unit into USB. You should see 3 green LEDs light up.
Now flash the firmware by executing the flasher application at the command line:
  1. flasher RaceCapturePro-X.X.X.elf
Flashing process
The flasher application should find the RaceCapture/Pro device and then start flashing new firmware. The red front panel LED on RaceCapture/Pro will flash while firmware is written.
Steps for Factory ROM bootloader
This is the backup mechanism for re-flashing bootloader firmware and should only be used when the primary firmware upgrading mechanism fails.
Prerequisite
Remove board from enclosure
Load Factory ROM Bootloader
  • Locate the 'test' button on the circuit board. If there is no test button installed, bridge the pads where the test button would be installed with a short jumper wire.
  • Press and hold the test button (or short the pads), then apply power to the RaceCapture/Pro board using the USB cable. Hold the button for 20 seconds.
    • This will write back the ROM factory bootloader into flash memory
  • Release the button and disconnect power.
Download the bootloader image
Download the bootloader image from the Downloads Area
  • The correct filename will start with bootloader-X.X.X.bin where X.X.X represents the version number. Example: bootloader-0.0.1.bin
Flash firmware
  • Re-apply power using the USB cable.
  • If you are prompted for drivers, install the drivers provided under the SAM-BA directory (typically found under C:\Program Files\Atmel\sam-ba_2.12\drv)
  • Once the drivers are loaded, you should see the device listed under Windows Device Manager - Ports as 'AT91 USB to Serial Converter'
    • If you do not see the board recognized this way, ensure you have the Atmel SAM-BA flash utility and drivers correctly installed. If you still have problems, repeat the previous step of loading the factory ROM bootloader.
    • If the board comes up as 'GPS Camera Detector' then Windows installed the wrong drivers. Use these instructions to remove the incorrect drivers before proceeding.
  • Run the SAM-BA flash utility.
    • Under 'Select the connection', select board as identified by Device Manager. The board will be defined as '\USBserial\COMXX' where COMXX is the COM port assigned in Device Manager.
    • Under 'Select your board', select 'at91sam7s256-ek'.
  • On the Flash tab, under 'Download/Upload File' select button next to 'Send File Name'. Browse to the bootloader firmware image, which will be a file ending in .bin (e.g. bootloader-0.0.1.bin)
  • Click the 'Send File' option in the program.
    • If prompted to 'Unlock' regions, click yes.
  • You should observe the firmware flashing progress in the window. When complete, you can remove power to RaceCapture/Pro.
Re-assemble RaceCapture/Pro
  • Slide the circuit board back in to the enclosure, aligning it with the holes in the end plate. It may be easier in some cases to remove both end plates to enable connectors/LEDs/button to fit into the end plate cut-outs. Ensure the smaller components, like LEDs fit correctly into their respective locations.
  • Slide mounting rails into place before installing 2nd end plate. Replace screws.
