ESP32-CAN-X2
ESP32-CAN-X2 is an innovative, and sophisticated development board that is specifically designed for CAN communication. This development board has all the features of a modern ESP32 development board, integrated Wi-Fi and Bluetooth, along with the extended CAN controller. AutosportsLabs has specifically designed it for advanced CAN communication along with fast processing and computation options. This is a complete how-to-use guide and this user guide will describe each and every step to use the board and harness the maximum potential of the board.
The prominent features of ESP32-CAN-X2 development board are as follows :
- The development board is based on ESP32-SE-WROOM-1-N8R8 microcontroller powerful dual-core Xtensa LX6 CPU running at up to 240 MHz.
- The development board has 384 KB ROM, 512 KB SRAM, 16 KB SRAM in RTC, 8 MB PSRAM
- Reset and Boot push button
- Integrated CAN transceivers
Getting started
This section will provide you with comprehensive information about the ESP32-CAN-X2 development board's key components, mechanical layout, and ratings. This detailed information helps you to use the board effectively and efficiently in your projects.
Microcontroller
As mentioned above, the ESP32-CAN-X2 Development Board is designed around the ESP32-S3-WROOM-1-N8R8 microcontroller in a 40-pin package. The connections between the development board and the microcontroller are simple and easy to understand. The majority of GPIO pins are directly connected with the external headers, SV1 & SV2, and some pins are reserved internal connections between the board and CAN controllers. The internal connections between the microcontroller and CAN controllers are shown in the CAN controller heading given below. The microcontroller pin layout is shown in Figure 2 given below.
External Connection Header
In addition to the microcontroller, external headers, SV1 & SV2, are the two other important components of this development board. SV1 is located on the left side, and SV2 is on the right, both comprising dual-row headers with 20 pins each. These headers provide connections for GPIOs, power output, ground (GND), power input, and CAN communication pins. Both of these header pinouts have standard size, allowing users to connect them using jumper wires, a breadboard, or even solder wires permanently onto the development board. However, while doing the wire connection the customer must make sure that none of them get short circuit. The details regarding the pin's names, numbers, outputs, and functions are given in the board layout section below.
CAN bus information
Board Pinout
Flashing firmware
