ESP32-CAN-X2
- Reset and Boot push button
- Integrated CAN transceivers
Getting started
Microcontroller
External Connection Header
CAN Controllers
6 pin JST-PH Connector
USB-C Socket
Board Layout
- Width : 42.10 mm
- Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
In CAN Bus communication, multiple controllers can act as a master, and multiple devices can act as a node. Each node can share the data with other nodes via the CAN bus. In modern cars, there are more than 70 ECUs, and using CAN communication each ECU acts as a node and can transfer the data to the CAN bus, this data is then available to all the ECUs, and ECU can then check the data and decide whether to receive or ignore it.
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Board Pinout
| 5 | RX Pin | USART RX |
| 6 | TX Pin | USART TX |
| 7-20 | GPIO Pins | GPIO's |
| 1-11 | GPIO Pins | GPIO's |
| 12-13 | Vin | Voltage Input |
| 14-15 | 5V | 5 Voltage Output |
| 16-18 | GND | Ground |
| 19-20 | 12 Vin | 12 Voltage Input |
Top Header Pinout
| 4 | GND | Ground |
| 5 | CAN2H/2.7A | high-level signal for the first CAN channel |
Flashing firmware
Firmware flashing in this development board is simple and straightforward. Following components are required for firmware flashings.
Hardware Components
- USB-C cable
Software Components
Step by step instruction
Step by step instruction for flashing ESP-32-X2 are as follows.
Adding ESP-32-X2 in Arduino Ide is a single time process and it step are as following.
- Open Arduino Ide
- Go to File > Preferences
Json URL : ( )
- In Board Manager search bar, type ESP-32-X2 and click on install to install the board board
- After installing, click on Tool > Boards and select ESP-32-X2 should be available there
Flashing
- Connect ESP-32-X2 board to your computer using a USB-C cable with your Arduino IDE open
Note : if you don’t see the COM Port in your Arduino IDE, you need to install the CP210x USB to UART Bridge VCP Drivers: https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers
- After successful uploading, you should see a “Done uploading.” message at bottom console. This console will also show error messages if there is any error.
Endless Opportunities
