ESP32-CAN-X2
  • Two LED’s : LED PWM & LED communication
  • Reset and Boot push button
  • Integrated antenna for long range communication
  • 6-pin header is strategically positioned at the top for CAN communication
  • Integrated CAN transceivers
Getting started
Figure 1
Microcontroller
Figure 2
External Connection Header
CAN Controllers
Figure 3
6 pin JST-PH Connector
USB-C Socket
Board Layout
  • Width  : 42.10 mm
  • Length : 72 mm
Figure 4
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Board Pinout
Figure 7
Pin Function Description
5 RX Pin USART RX
6 TX Pin USART TX
7-20 GPIO Pins GPIO's
1-11 GPIO Pins GPIO's
12-13 Vin Voltage Input
14-15 5V 5 Voltage Output
16-18 GND Ground
19-20 12 Vin 12 Voltage Input
Top Header Pinout
fIGURE 8
1 CAN1L/2.7A low-level signal for the first CAN channel
2 CAN2L/2.7B low-level signal for the second CAN channel
3 CAN2H/2.7B high-level signal for the second CAN channel
4 GND Ground
5 CAN2H/2.7A high-level signal for the first CAN channel
6 +12V_ Aux 6-12v power supply
Flashing Firmware
Hardware Components
  • USB-C cable
Software Components
Note : Link to download Arduino IDE : https://www.arduino.cc/en/software
Step by step instruction
  • Open Arduino Ide
  • Go to File > Preferences
Figure 7
Json URL : ( )
Figure 8
Figure 9
  • In the Board Manager search bar, type ESP-32-X2 and click on install to install the board
Figure 10
  • After installing, click on Tool > Boards and select ESP-32-X2
Flashing
  • Select ESP-32-X2 in Tools > Board menu
Figure 11
Endless Opportunities
Sample Arduino Project
