RacecapturePro MK4 hardware install
Mounting Orientation
Recommended Orientation
Alternate Orientations
  • Upside Down
  • Vertical / On Edge
Calibration and Remapping
Mounting Dimensions
  1. 12-pin female M12 connector for analog input devices.
  2. SMA connector for GPS antenna connection.
  3. 12-pin female M12 connector for digital input and RPM sensors.
  4. 6-pin female M8 connector for CAN1, CAN2, and power connections.
  5. 4-pin female M8 connector for CAN1 and power connections.
