RacecapturePro MK4 hardware install
Mounting Orientation
Recommended Orientation
Alternate Orientations
  • Upside Down
  • Vertical / On Edge
Calibration and Remapping
Mounting Dimensions
  1. 12-pin female M12 connector for analog input devices.
  2. SMA connector for GPS antenna connection.
  3. 12-pin female M12 connector for digital input and RPM sensors.
  4. 6-pin female M8 connector for CAN1, CAN2, and power connections.
  5. 4-pin female M8 connector for CAN1 and power connections.
M12 Analog / Digital Connectors
M12 Analog / Digital ConnectorsCaption text
6 Vref 5v @ 0.5A 5v @ 0.5A
9 Analog/Digital B Analog 7 GPIO 3
10 Ground
11 Ground
12 Ground
M8 Connectors 4-Pin CAN1+Power
Pin Connection Notes
1 CAN 1 low
2 Power 9-24v / 1A (~12W)
3 CAN 1 high
4 Ground
1 CAN 1 low
2 CAN 2 low
3 CAN 2 high
4 Ground
5 CAN 1 high
6 Power 9-24v / 1A (~12W)
