RacecapturePro MK4 hardware install
Mounting Orientation
Recommended Orientation
Alternate Orientations
  • Upside Down
  • Vertical / On Edge
Calibration and Remapping
Mounting Dimensions
  1. 12-pin female M12 connector for analog input devices.
  2. SMA connector for GPS antenna connection.
  3. 12-pin female M12 connector for digital input and RPM sensors.
  4. 6-pin female M8 connector for CAN1, CAN2, and power connections.
  5. 4-pin female M8 connector for CAN1 and power connections.
M12 Analog / Digital Connectors
M12 Analog / Digital ConnectorsCaption text
6 Vref 5v @ 0.5A 5v @ 0.5A
9 Analog/Digital B Analog 7 GPIO 3
10 Ground
11 Ground
12 Ground
M8 Connectors 4-Pin CAN1+Power
Pin Connection Notes
1 CAN 1 low
2 Power 9-24v / 1A (~12W)
3 CAN 1 high
4 Ground
1 CAN 1 low
2 CAN 2 low
3 CAN 2 high
4 Ground
5 CAN 1 high
6 Power 9-24v / 1A (~12W)
OBDII CAN cable
SMA Connector
Antenna Placement Guide
Powering
Power Requirements
Power requirements
Voltage 9-24v
Current 1A (~12W)
Sensor Connectivity
Analog Inputs pins
Analog Channel Speccifications
Channels 9 analog input channels, with 8 external and 1 internal for monitoring battery or supply voltage
Voltage Range 0-5V
Voltage Protection Up to 400V (intermittent)
ADC Precision 12-bit
Maximum Sample Rate 1000Hz
Mapping Can be configured as Raw, using a linear formula, or an interpolated map
Note: You can use an analog port to monitor the states of 12V switches, lights, or other 5V-12V On/Off devices. It is recommended to use an inline 10K 1/4 watt resistor to ensure proper functioning and protection of the system. The input should be mapped such that a voltage range of 0-3.0V corresponds to a state of 0, and a voltage range of 3.01V and above corresponds to a state of 1. Even when 12V is applied, the system will display a maximum of approximately 5V, ensuring safe monitoring and accurate state detection of the connected devices.
Frequency / RPM Input
You can connect RPM, wheel speed, and other pulse-type sensors to the RaceCapture/Pro frequency input pins. These inputs are designed to handle various types of frequency-based signals, providing accurate and reliable data for performance monitoring and analysis.
Frequency / RPM Input Speccifications
Mapping Supported The input signals can be mapped to RPM, frequency, or period measurements.
Signal input quality
To ensure accurate measurements, verify that the source provides a relatively clean pulse signal transitioning between 0 and 5-12 volts. Clean signals are essential for precise and reliable data acquisition.
Special note about RPM inputs
For the best performance and reliability, it is preferred to obtain a clean RPM signal directly from the engine's ECU (Engine Control Unit). This approach minimizes the risk of noise and ensures a more stable signal.
  • Verify if the signal you're tapping is driving the ignition coil directly, or if it's feeding into an igniter. If it's powering the coil directly, use the CoilX module to buffer/filter the high-voltage signal.
  • If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer/filter the noisy, high-voltage component.
