MJLJ V4 Operation Guide
Revision as of 17:58, 9 July 2008 by Brentp (talk | contribs) (→Trigger Offset: mior edit for clarification.)
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Serial Cable
You may construct a cable by modifying a 4 conductor modular phone cable per the wiring diagram, or you may use cable + adapter available through our online store.
Be careful to wire the actual pin number for your DB9 connector- a common mistake is to forget the pins are in reverse when soldering from the back of the connector.
If you are using the DB9-RJ11 adapter, wire the 3 connectors as shown in the picture, then snap the DB9 connector onto the plastic shell.
(Note, DB9 is shown from back side)
Common connection problems
Timeout reading runtime data
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
Auxiliary Input
Advance Correction
Configuring Engine Parameters
Number of Cylinders
Cranking Advance
Specify the Ignition advance used during cranking. The controller will use this value when the engine RPM drops below approximately 500 RPMs.
Trigger Offset
EDIS PIP Filter Level
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
Adjusting Load / RPM Bins
  • Ctrl-B in the main window
Advance Correction
  • Bins: The Bins determine which Advance Correction value is selected based on the value measured from the Auxiliary Input channel. You can specify a spread of values that suits your preferences, creating coarse or fine regions between bins.
  • Correction: The Ignition Advance Correction for the matching Bin. This value can be +/- 59 degrees.
  • Peak Hold: Hold the advance correction for X ignition events after a peak value is detected on the Auxiliary Input channel. After the Peak Hold decays, the Advance correction drops down to the correction value for the current Auxiliary Input value. A value of zero disables this feature.
Operation
User Output Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
Shift Light
Rev Limit
Commit to Flash
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Gauge / Label Customization
  • Auxiliary Input Label: Specify a label to match your particular use. Example: "Coolant Temp"
Edit calibration values
Enable hardware switch
Important Usage Notes
Charting / Runtime view
Tuning Perspective
Editing the Ignition Map
Hot Keys
Visualization
Data logging
Quick Data Logging
Mark Datalog
Stop Logging
Open Datalog
Logfile Format
  • RPM: Engine RPM
