BMW E46 CAN
Revision as of 18:08, 28 July 2025 by Brentp (talk | contribs)
Required parts
Plug and play harness system
Use the Power + CAN pigtail to supply power + data to the RaceCapture system:
See our Harness Specifications for the cable pinout
Estimated Time
2-3 hours, depending on level of wiring experience. The most time consuming part is splicing the CAN, power and ground wires into the cable.
CAN wires
  • Yellow/Red = CAN+ (high)
  • Yellow/Brown = CAN- (low)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Option #1: OBD-II port power
Connection BMW Power + CAN pigtail
+12v Yellow-Red (OBD-II connector) Red
Ground Brown (OBD-II connector) Black
CAN High Yellow/Red Green
CAN Low Yellow/Brown White
Splice power and ground wires
Configure RaceCapture/Pro
Set Baud Rate
E46 CAN bus Preset
Verifying real-time data
Legacy RaceCapture systems with RJ45
DIY Cable
  • Crimp tool
  • Wire cutter
  • Wire stripper
  • Philipps screwdriver
  • Multimeter
  • 22-26 gauge wire
CAN Bus connection
  • Orange: CAN1 High
  • Green/white: CAN1 Low
  • Brown: Power
  • Orange/white: Ground
Use the following diagram:
Additional resources
