Ford EDIS technical information
Revision as of 07:38, 20 October 2008 by Brentp (talk | contribs) (→Crank pulley modifications: grammar)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
The pattern can be as elaborate as replicating the trigger wheel teeth pattern into the pulley to simply milling/drilling a series of holes representing the pattern. Regardless of technique used, it's imperative the pattern is accurately machined into the pulley to ensure proper ignition timing.
courtesy of Alexander_Monday
courtesy of pope101
Alternate coil wiring
The following oscilloscope image shows the current limiting 'feature' of the EDIS module. The EDIS module will automatically adjust the dwell time to charge the coil primary up to a pre-determined current limit.
--insert plot here--
The plot illustrates the effects of active current limiting. The coil driver wired with two primares shows 1/2 the dwell time of the other coil primary, wired normally.
