RaceCapture-Pro MK2
Revision as of 15:41, 10 December 2008 by Brentp (talk | contribs) (RaceCapture Introduction: clarify)
Autosport Labs RaceCapture is a powerful data acquisition and control system for motorsport applications, presented at a break-through price.
Beta testing in 2009!
If you are interested in participating in our beta test program, email us with your request, including a short note explaining how you might benefit from the system, and a bit on your relevant background and experience. This information will help us qualify you as a beta-tester. Previous 'good-citizen' beta-testers will get preferred placement.
File:Race cap board sm.jpg File:Race cap board case sm.jpg
Capabilities
Inputs and outputs
    • Measure sensors or receive input from other devices...
    • Measure RPM, wheel speed, anything with a measurable interval. One channel is optically isolated for direct connection to ignition coil.
    • Control other systems or even over-ride OEM sensors
  • 3 configurable digital channels, configurable for input or output
  • Input for precision 3 channel accelerometer (+/- 2G per axis)
    • Measure and log 3-D G-Force in realtime with one of the industry's most accurate and precise accelerometers!
  • GPS module input
Logging
Power
    • Enough power for high frequency logging and running complex, user-defined logic
Mechanical
  • On-board Status LEDs
Flexibility
The Intangibles
  • Far more than a data-logging system; the combination of a powerful processor with inputs and outputs allows this system to be used for many different applications!
