RaceCapture-Pro MK2
Revision as of 00:55, 3 January 2009 by Brentp (talk | contribs) (→RaceCapture Introduction: trim whitespace)
Autosport Labs RaceCapture is a powerful data acquisition and control system for motorsport applications, presented at a break-through price.
Beta testing in 2009!
If you are interested in participating in our beta test program, email us with your request, including a short note explaining how you might benefit from the system, and a bit on your relevant background and experience. This information will help us qualify you as a beta-tester. Previous 'good-citizen' beta-testers will get preferred placement.
Capabilities
Inputs and outputs
  • Input for precision 3 channel accelerometer module (+/- 2G per axis, 3G optional)
  • GPS module input
Logging
Power
Mechanical
  • On-board Status LEDs
Flexibility
The Intangibles
  • Far more than a data-logging system; the combination of a powerful processor with inputs and outputs allows this system to be used for many different applications!
