RaceCapture-Pro MK2
Revision as of 04:10, 3 January 2009 by Brentp (talk | contribs) (removed toc)
RaceCapture Introduction
Autosport Labs RaceCapture is a powerful Data Acquisition and Control system for motorsport applications, presented at a break-through price.
Beta testing in 2009!
If you are interested in participating in our beta test program, email us with your request, including a short note explaining how you might benefit from the system, and a bit on your relevant background and experience. This information will help us qualify you as a beta-tester. Previous 'good-citizen' beta-testers will get preferred placement.
Capabilities
Input and Output Channels
RaceCapture offers 20 channels for logging and control, enough to handle the most complex logging and control tasks
  • Input for precision 3 channel accelerometer module (+/- 2G per axis, 3G optional)
  • GPS module input
Logging
Power
Mechanical
  • On-board Status LEDs
The Intangibles
Flexibility
Infinite Possibilities
  • Far more than a data-logging system; Inputs and outputs coupled with a powerful processor yield endless customization
Images
Board Connections
