Ford EDIS technical information
Revision as of 23:25, 9 July 2009 by ChidoMroli (talk | contribs)
http://monerla.com/letobocpasca.html[acelgetolo] [[1][acelgetolo]]
"acelgetolo":http://olobasbasl.com/racbasbocela.html
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
Crank pulley modifications
courtesy of Alexander_Monday
courtesy of pope101
Alternate coil wiring
