Trigger Wheel Designs
Revision as of 18:52, 25 July 2009 by Brentp (talk | contribs) (Per Vehicle Installations: added link to forums)
Crank Pulley Strategies
Adapting Trigger Wheel to Existing Crank Pulley
The most common approach is to mate a pre-made Trigger Wheel to the existing OEM crank pulley. Often the trigger wheel must be mounted on the outboard portion of the crank pulley as there is usually not enough room between the crank pulley and block.
Toyota 4AG Trigger wheel installation
Machined crank pulley with timing adapted Closeup view of adapted timing wheel Machined pulley with timing wheel adapted
Machining Pattern into Crank Pulley
courtesy of Alexander_Monday
courtesy of pope101
Sensor Bracket Design
Sensor brackets must be designed to be extremely rigid to maintain proper alignment and clearance under all operating conditions. A weak bracket design will vibrate during engine operation- especially at certain RPM ranges.
Symptoms of Poor Bracket Design
  • Strikes/rubbing on trigger wheel and sensor
    • Sensor is making contact against trigger wheel during engine operation
  • Engine misfiring / hesitation during certain RPM ranges
    • Sensor is vibrating excessively- affecting the VR Signal supplied to the Ignition System. The system can handle signal variances up to a certain point; beyond this point the system loses 'sync' with the trigger wheel, causing the mis-firing.
Without access to sophisticated tools for mechanical design and simulation, most will take the pragmatic approach and 'over design' the bracket for strength and rigidity.
Example Bracket Design
Not the bracket thickness of in relation to the size. VR Sensor and bracket Modified crank pulley mounted with VR Sensor
Be sure to see our Forums for the latest designs contributed by the community
1275 A-Series Austin Mini
  • Courtesy of NITROPIXIE
  • Year: 1989
  • Trigger Wheel Source: Made at local engineering shop for £70. Teeth are 10mm deep as VR sensor is located at 90 degs to wheel. Used a 998 pulley without damper. Rivets ground out and holes threaded. Triggerwheel is mounted with 4 bolts. 10 deg adjustment in triggerwheel. Triggerwheel diameter equals the pully diameter.
  • VR Sensor Source: Ford Ka
  • VR Location/mounting bracket: Radiator now mounted at the front and used the old radiator mount bracket to form a bracket to now hold the VR sensor as in picture. Strap holds Vr sensor. Vr sensor can only be adjusted in distance from wheel.
