MJLJ V4 vehicle installation guide
Revision as of 15:28, 14 December 2009 by Brentp (talk | contribs) (→Parts you will need: added link to online store)
System Overview
Parts you will need
To complete your installation, you will need the following components.
EDIS Donor vehicles
EDIS-4 Ford Escort 1990-99 US
Ford Fiesta 1990-99 Europe
Mazda 121 1996-2001 Europe
Ford Escort 1990-2000 Europe
Ford Sierra 1990-93 Europe
Ford Explorer 1990-97 US
Mazda Navajo 1990-97 US
Ford Aerostar 1990-97 US
Lincoln Town Car 1990-97 US
Ford Thunderbird 1990-97 US
Mercury Cougar 1990-97 US
Ford Mustang 5.0 1990-97 US
  • Component Suppliers
Ford EDIS component suppliers
Location Company
USA Boost Engineering
UK Trigger Wheels
EDIS installation
Sensor Position
EDIS-4 90 9
EDIS-6 60 6
EDIS-8 50 5
Typical Trigger Wheel Installation
Megajolt Lite Jr. Wiring
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Smiths RVI type tachometers
User Defined Outputs and Shift Light
Usage
Enabling Option Switch
Rev Limit control
Hard Rev Limit
Soft Rev Limit
Auxiliary Input
Analog input source
Hardware Modification
MJLJ Operation
Verification Steps
Verifying MJLJ operation
Verifying Power
Verifying Signals
Expected Voltages
* 0 volts when not running;
* 0V when engine not running;
