RaceCapture-Pro MK2
Revision as of 15:45, 27 April 2012 by Brentp (talk | contribs) (→Power: spiced it up a bit)
Impact
Significance
Capabilities
Input and Output Channels
  • 4 configurable 0-5v analog or frequency output channels
  • 10Hz GPS module input
      • Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
  • Auxiliary Serial Port
  • Digital expansion port
    • A high speed port provides the ability to add CAN bus expansion, more analog or digital channels, integrate specialty sensor hardware such as thermocouple amplifiers, and so on
Logging
Power
  • 48MHz 32 bit ARM processor
Input/Output Protection
  • 45v protection on all input pins
Mechanical
  • Compact, rugged design
  • On-board Status LEDs
Flexibility
On-board scripting
Some Examples:
Software Connectivity
  • Customize logging channels
  • View Runtime Data
  • Edit custom scripting
Infinite Possibilities
Board Connections
Images
Rev E board with on-board accelerometer module
RaceCapture/Pro with GPS Module
<br.>
