RaceCapture/Pro MK1 firmware upgrade
Save your configuration
Download the new firmware and firmware update utility from Downloads section
You will need both the flasher utility as well as the firmware image you wish to use.
Place these downloaded files in a known directory on your computer. for example, c:\firmware
Install flasher device driver
If this is your first time installing new firmware, you will need to install the device drivers for the flasher utility. The drivers are included with the firmware update utility zip file. Download Here
install the bootloader drivers by running at the command line:
c:\firmware>bootloader_drivers.exe
Answer yes to the all of the prompts before proceeding.
Note: You won't have to do this again the next time you load new firmware
Open a command prompt
e.g. for Windows:
cd c:\firmware
Connect RaceCapture/Pro
while holding down the front panel button connect RaceCapture/Pro to your computer using the USB cable.
Issue firmware flash command
At the command prompt, issue the command flasher RaceCapturePro-X.X.X.elf where X.X.X represents the firmware version. Example:
The flasher application should find the RaceCapture/Pro device and then start flashing new firmware.
Steps for Factory ROM bootloader
This is the backup mechanism for re-flashing firmware and should only be used when the primary firmware upgrading mechanism fails.
Prerequisite
- Windows, Linux: download from Atmel's web site Direct download link
- Linux alternative: Linux4SAM
Remove board from enclosure
Load Factory ROM Bootloader
- Locate the 'test' button on the circuit board. If there is no test button installed, bridge the pads where the test button would be installed with a short jumper wire.
- Press and hold the test button (or short the pads), then apply power to the RaceCapture/Pro board using the USB cable. Hold the button for 20 seconds.
- (This will write back the ROM factory bootloader into flash memory)
- Release the button and disconnect power.
Flash firmware
- Re-apply power using the USB cable.
- If you are prompted for drivers, install the drivers provided under the SAM-BA directory (typically found under C:\Program Files\Atmel\sam-ba_2.12\drv)
- Once the drivers are loaded, you should see the device listed under Windows Device Manager - Ports as 'AT91 USB to Serial Converter'
- If you do not see the board recognized this way, ensure you have the Atmel SAM-BA flash utility and drivers correctly installed. If you still have problems, repeat the previous step of loading the factory ROM bootloader.
- If the board comes up as 'GPS Camera Detector' then Windows installed the wrong drivers. Use these instructions to remove the incorrect drivers before proceeding.
- Run the SAM-BA flash utility.
- Under 'Select the connection', select board as identified by Device Manager. The board will be defined as '\USBserial\COMXX' where COMXX is the COM port assigned in Device Manager.
- Under 'Select your board', select 'at91sam7s256-ek'.
- On the Flash tab, under 'Download/Upload File' select button next to 'Send File Name'. Browse to the bootloader firmware image, which will be a file ending in .bin (e.g. bootloader-0.0.1.bin)
- Click the 'Send File' option in the program.
- If prompted to 'Unlock' regions, click yes.
- You should observe the firmware flashing progress in the window. When complete, you can remove power to RaceCapture/Pro.
Re-assemble RaceCapture/Pro
- Slide the circuit board back in to the enclosure, aligning it with the holes in the end plate. It may be easier in some cases to remove both end plates to enable connectors/LEDs/button to fit into the end plate cut-outs. Ensure the smaller components, like LEDs fit correctly into their respective locations.
- Slide mounting rails into place before installing 2nd end plate. Replace screws.
