RaceCapturePro Lua Scripting
Revision as of 14:23, 9 April 2013 by Brentp (talk | contribs) (→Scripting functions for RaceCapture/Pro: more formatting and additional functions)
This page is under construction. Check back soon!
getGpio( port )
Retrieves the state of the GPIO ports
  • params
    • port: integer 0 - 2
  • returns:
    • state: 1 = port is high, 0 = port is low
When the port is configured for input mode, a voltage high input (> 2 volts) will read as 1; a voltage low will read as 0. A disconnected port will read as high due to the internal pullup resistor.
When the port is configured as output, the port reads 1 when the port is activated (output transistor is connected to ground) and 0 when the port is deactivated (pullup resistor is active)
setGpio ( port, state )
Sets the state of the GPIO port when the port is configured for output mode.
  • params
    • port: integer 0 - 2, state - 1 = output active; 0 = output inactive
  • returns:
    • none
getButton()
  • params
    • none
  • returns
isSDCardPresent
Indicates if an SD card is present in the socket
present isSDCardPresent()
  • params
    • none
  • returns
    • present: 1 = SD card is present in socket; 0 = SD card not present
isSDCardWritable()
Indicates if the SD card is writable (lock switch on SD card is active)
  • params
    • none
  • returns
    • writable: 1 = SD card is writable; 0 = SD card is not writable
setPwmDutyCycle( port, dutyCyclePct )
  • params
    • port: PWM / Analog output port 0 - 3
  • returns
    • none
Sets the duty cycle of the specified PWM / Analog output port to the specified duty cycle percentage
setPwmPeriod( port, period )
  • params
    • period: The period value
    • returns
  • none
Sets the period of the specified PWM / Analog output port to the specified period
setAnalogOut( port, voltage )
  • params
    • returns
  • none
Sets the output voltage of the specified PWM / Analog output port to the specified period. A convenience function equivalent to setPwmDutyCycle that translates voltage to PWM percentage.
getTimerRpm
getTimerPeriodMs
getTimerPeriodUsec
getTimerFrequency
getTimerRaw
resetTimerCount
getTimerCount
getAnalog
getAnalogRaw
readSerial
writeSerial
getGpsLatitude
getGpsLongitude
getGpsSpeed
getGpsQuality
getGpsTime
getLapCount
getLapTime
getGpsSec
getAtStartFinish
getTimeDiff
getTimeSince
getAccel
getAccelRaw
startLogging
stopLogging
setLed
flashLoggerConfig
setAnalogSampleRate
getAnalogSampleRate
setAnalogScaling
getAnalogScaling
setPwmClockFrequency
getPwmClockFrequency
setPwmSampleRate
getPwmSampleRate
setPwmOutputConfig
getPwmOutputConfig
setPwmLoggingConfig
getPwmLoggingConfig
setPwmStartupDutyCycle
getPwmStartupDutyCycle
setPwmStartupPeriod
getPwmStartupPeriod
setPwmVoltageScaling
getPwmVoltageScaling
setGpsInstalled
getGpsInstalled
setGpsStartFinish
getGpsStartFinish
setGpsPositionSampleRate
getGpsPositionSampleRate
setGpsSpeedSampleRate
getGpsSpeedSampleRate
setGpsTimeSampleRate
getGpsTimeSampleRate
setLapCountSampleRate
getLapCountSampleRate
setLapTimeSampleRate
getLapTimeSampleRate
setGpioSampleRate
getGpioSampleRate
setGpioConfig
getGpioConfig
setTimerSampleRate
getTimerSampleRate
setTimerConfig
getTimerConfig
setTimerPulsePerRevolution
getTimerPulsePerRevolution
setTimerDivider
getTimerDivider
calculateTimerScaling
getTimerScaling
setAccelInstalled
getAccelInstalled
setAccelSampleRate
getAccelSampleRate
setAccelConfig
getAccelConfig
setAccelChannel
getAccelChannel
setAccelZeroValue
getAccelZeroValue
calibrateAccelZero
