RaceCapturePro FAQ
How do I automatically start/stop RaceCapture/Pro logging
To automatically start logging when the vehicle is moving more than 10mph, paste the following into the script window in RaceAnalyzer, and then write the configuration to RaceCapture/Pro:
Note, this will override the behavior of the front mounted logging trigger button.
What happens if power is lost while logging to SD?
RaceCapture/Pro streams data continuously to the SD card, and every 10 seconds synchronizes the file markers on the file so that if power is suddenly lost during logging, the data since the last file marker synchronization is retained.
How do I configure the start/finish line for calculating lap time and tracking lap counts?
