RaceCapturePro Lua Scripting
Example Scripts and How-Tos
[[RaceCapturePro Lua Scripting Examples|Lua Scripting Examples]
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
- returns:
- none
getButton()
- params
- none
- returns
PWM / Analog Output functions
- params
- returns
- none
setPwmPeriod( channel, period )
- params
- period: The period value
- returns
- none
- params
- returns
- none
Timer / RPM Sensor Functions
getTimerRpm(channel)
- params
- channel: Timer channel 0 - 3
- returns: RPM value
getTimerPeriodMs(channel)
- params
- returns: millisecond value
getTimerFrequency(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
Analog Sensor Functions
getAnalog(channel)
- params
- channel: Analog input channel 0 - 7
getAnalogRaw(channel)
Reads the raw analog value for the specified analog input channel.
- params
- returns: The raw value measured by the 10 bit Analog to Digital Converted on the specified analog channel, between 0 - 1023
getAccel(channel)
- params
- channel (0 - 2 for accelerometer, 3 for yaw gyro sensor)
- returns
getAccelRaw(channel)
- params
- returns
- The raw accelerometer value
GPS Sensor Functions
getGpsPos()
- params
- none
- returns
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getGpsDist()
- params
- (none)
- returns
- The distance, in Miles
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getGpsSec()
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
getTimeDiff(time1, time2)
- params
- time1
- time2
- returns
getTimeSince(time)
- params
- time
- returns
CAN Bus functions
initCAN()
- params
- returns
- 1 if successful, 0 if initialization fails.
txCAN()
- params
Example:
id = 1234 ext = 0 data = [11,22,33] res = txCAN(id, ext, data)
rxCAN()
- params
- timeout (optional). read timeout in milliseconds
- returns
If no CAN message was received, the function returns NIL
Example:
id, ext, data = rxCAN(100) --100ms timeout
println("CAN rx: " ..id .." " ..data[0]) --print ID and first element of received message
setCANfilter()
- params
- filter ID (0-5). Up to 6 filters are supported. Typically you will use filter ID 0-1.
- filter Pattern value for CAN filter
- returns
- 1 for success, 0 for fail
setCANMask()
available in firmware 2.0 Sets the specified CAN filter Mask, to ignore messages with a particular address. Must use in combination with setCANFilter() to set a complete filter and mask
- params
- Mask (0-1). Up to 2 masks are supported. Typically you will use mask 0.
- filter Pattern value for CAN mask
- returns
readOBD2()
- params
- returns
Logger Control Functions
startLogging()
Begins a logging session
- params
- (none)
- returns
- (none)
stopLogging()
- params
- (none)
- returns
- (none)
setLed(led, state)
- params
- led (1-3)
- state : 1 = on, 0 = off
- returns
- (none)
readSerial(port)
- params
- port: Serial port 0 - 1
- returns: a line of serial data
writeSerial(port, data)
- params
flashLoggerConfig()
- params
- (none)
- returns
- (none)
setAnalogSampleRate(channel, rate)
Sets the sample rate for the specified channel
- params
- channel
- sampleRate
- returns
- (none)
getAnalogSampleRate()
Gets the sample rate for the specified channel
- params
- (none)
- returns
- (none)
setPwmClockFrequency(freq)
- params
- returns
- (none)
getPwmClockFrequency()
- params
- (none)
- returns
setPwmSampleRate(channel, rate)
Sets the sample rate for the specified PWM channel
- params
- channel: the PWM channel
- rate: the sample rate to set
- returns
- (none)
getPwmSampleRate(channel)
Gets the PWM sample rate for the specified PWM channel
- params
- returns
- rate: the currently configured sample rate
setGpsSampleRate
Sets the sample rate for GPS logging features
- params
- sampleRate - sample rate in Hz. Function has no effect if the specified value does not match a supported sample rate.
- returns
- (none)
getGpsSampleRate
- params
- (none)
- returns
- sampleRate - the configured sample rate, in Hz
setGpioSampleRate
Sets the sample rate for the specified GPIO channel
- params
- channel - a supported GPIO channel (0 - 2)
- returns
- (none)
getGpioSampleRate
Gets the sample rate for the specified GPIO channel
- params
- (none)
- returns
setGpioConfig(channel, config)
Sets the input/output configuration for the specified GPIO channel
- params
- config - 0 = input mode; 1 = output mode. Note, hardware jumpers must also be set to reflect configuration
- returns
- (none)
getGpioConfig
Gets the input/output configuration for the specified GPIO channel
- params
- returns
setTimerSampleRate
Sets the sample rate for the specified timer channel
- params
- channel - a supported timer channel (0 - 2)
- returns
- (none)
getTimerSampleRate
Gets the sample rate for the specified timer channel
- params
- (none)
- returns
setAccelSampleRate
Sets the sample rate for the specified accelerometer or gyro channel
- params
- channel - a supported channel (0,1,2 for accelerometer; 4 for yaw sensor gyro)
- returns
- (none)
getAccelSampleRate
Gets the sample rate for the specified accelerometer or gyro channel
- params
- returns
calibrateAccelZero
- params
- (none)
- returns
- (none)
setGpsStartFinish(latitude, longitude, target)
Sets the start/finish line target, used for lap time calculations.
- params
- latitude - latitude in decimal degrees
- longitude - longitude in decimal degrees
- target - radius of GPS target, in degrees
- returns
- (none)
latitude, longitude, target = getGpsStartFinish()
Gets the start/finish line target, used for lap time calculations.
- params
- (none)
- returns
Virtual Channels
addChannel()
available in firmware 2.0 Adds a virtual channel. This virtual channel remains in memory during runtime; it is not persisted in the configuration. Up to 10 virtual channels can be created.
- params
- name: The name of the channel. Must be a channel name known to the system, up to 10 characters long.
- returns
- the Id of the new virtual channel, or nil if the virtual channel could not be created.
setChannel()
- params
- Id: the ID of the channel provided by addChannel()
- Value: the new value to set for the virtual channel
Example:
id = addChannel("EGT", 1) --channel name EGT must exist in the list of known channels
temp = temp * 1000
