Megajolt
Revision as of 04:45, 28 April 2014 by Brentp (talk | contribs) (moved Megajolt2 to Megajolt)
The Megajolt2 Family
The Megajolt family represents the line of programmable, crank fired ignition control systems.
Megajolt/2
Megajolt/2 is a high performance programmable crank-fired ignition system optimized for 4 cylinder applications
Capabilities
  • 4,6 or 8 cylinders in wasted spark mode
  • 15K RPM capable
  • 0.1 degree timing resolution
  • 32 bit Infineon XMC4000 - 120MHz
  • Single VR Sensor input
  • 2 on-board coil drivers
  • Soft and hard rev limit
  • Designed to work with commodity OEM sensors and coil packs
  • Initial support for 36-1 trigger wheel; other trigger wheel configurations to follow
  • up to 16x16 ignition map with linear interpolation
    • Dual, on the fly switchable ignition map support
  • 2 User defined digital outputs
  • 3 analog input channels
    • Throttle Position, Temperature and Aux
    • Ignition advance correction for Temperature and Aux
  • On-Board MAP sensor
  • USB or Bluetooth programming interface
Megajolt/C
Summary
Megajolt/C is a Programmable Crank Fired ignition targeted for intelligent coil-on-plug modules or external igniter applications.
Capabilities
  • Supported configurations
    • Up to 8 cylinders in true coil-on-plug mode
    • Up to 12 cylinders in wasted spark mode
  • 15K+ RPM capable
  • Dual VR Sensor input
    • Crank Sensor + Cam Angle Sensor input
  • 8 logic-level coil driver outputs
    • Designed to drive coil-on-plug or coil-near-plug modules such as the GM LS-1, LS-2, BMW or similar coil modules with built-in coil drivers
    • TPS, Temperature and Aux
    • Ignition correction for Temperature and Aux
Megajolt/Micro
Summary
Ultra compact EDIS ignition control
Capabilities
    • 4,6,8 cylinders
  • Soft Rev Limit capable
  • 1 degree timing resolution
  • 10x10 ignition map with linear interpolation
  • TPS/MAP, temperature and Aux input
  • 2 User-defined digital outputs
  • Provision for on-board MAP sensor
  • Bluetooth interface option
