Ford EDIS technical information
Revision as of 17:51, 5 June 2007 by DraZ2y (talk | contribs)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
