RaceCapturePro Downloads
RaceCapture/Pro MK2
App
Windows
Mac OS X
Mac installer coming soon!
Linux
Packages coming soon!
Driver
- OS X: No driver needed
- Linux: No driver needed
App
Firmware
- RaceCapture/Pro MK2 firmware 2.7.5
- RaceCapture/Pro MK2 firmware 2.7.4
- RaceCapture/Pro MK2 firmware 2.7.3
- RaceCapture/Pro MK2 firmware 2.7.2
RaceCapture/Pro MK1
Firmware
RaceCapture App
- Linux: currently supported (run from source code; installer coming soon)
- OS X: experimental support - USB interface fails to communicate (possible driver issue)
- Android: port scheduled
- iOS: port scheduled
Windows
Linux
Previous Versions
Race Analyzer Downloads
Latest
Mac OS X
Linux
Release Notes
Sample Logfiles
Previous Releases
- Race Analyzer 1.1.14
- Race Analyzer 1.1.13
- Race Analyzer 1.1.12
- Race Analyzer 1.1.11
- Race Analyzer 1.1.10
- Race Analyzer 1.1.9
- Race Analyzer 1.1.8
- Race Analyzer 1.1.7
- Race Analyzer 1.1.6
- Race Analyzer 1.1.4
- Race Analyzer 1.1.3
Driver Downloads
Windows 8 Note
- Windows 8 introduced restrictions on unsigned drivers. You need to allow unsigned drivers before installing the RaceCapture/Pro drivers.
For firmware version 1.2 and higher
Firmware Downloads
Latest
Firmware Instructions
Release Notes
Previous Releases
- RaceCapture/Pro firmware 1.2.7
- RaceCapture/Pro firmware 1.2.6
- RaceCapture/Pro firmware 1.2.5
- RaceCapture/Pro firmware 1.2.4
- RaceCapture/Pro firmware 1.2.3
- RaceCapture/Pro firmware 1.1.13
- RaceCapture/Pro firmware 1.1.12
- RaceCapture/Pro firmware 1.1.11
- RaceCapture/Pro firmware 1.1.10
- RaceCapture/Pro firmware 1.1.9
- RaceCapture/Pro firmware 1.1.8
- RaceCapture/Pro firmware 1.1.6
Bootloader Releases
Firmware update utility
