RaceCapturePro Downloads
RaceCapture/Pro MK2
App
Windows
Mac OS X
Mac installer coming soon!
Linux
Packages coming soon!
Driver
- OS X: No driver needed
- Linux: No driver needed
App
Firmware
How to update MK2 Firmware
Save your configuration
- Press the 'Configuration' button to navigate to the configuration section.
- On the left menu, select Firmware
- On the firmware screen, press the button "Update Firmware"
- Navigate to the firmware file ending in ".ihex"
- Select this file. The firmware will update and show a percentage progress indicator.
- If there is a problem detecting RaceCapture/Pro, unplug/replug and restart the app.
Alternative method
- While holding down the button on RaceCapture/Pro, power it up by plugging in to USB.
- You should observe a rapidly flashing red LED on the unit.
- Start the app; it will not be able to connect normally.
- Navigate to the configuration/firmware update screen, select the firmware file and update the firmware.
RaceCapture/Pro MK1
Firmware
RaceCapture App
- Linux: currently supported (run from source code; installer coming soon)
- OS X: experimental support - USB interface fails to communicate (possible driver issue)
- Android: port scheduled
- iOS: port scheduled
Windows
Linux
Race Analyzer Downloads
Latest
Mac OS X
Linux
Release Notes
Sample Logfiles
Driver Downloads
Windows 8 Note
- Windows 8 introduced restrictions on unsigned drivers. You need to allow unsigned drivers before installing the RaceCapture/Pro drivers.
For firmware version 1.2 and higher
Firmware Downloads
Latest
Firmware Instructions
Release Notes
Bootloader Releases
Firmware update utility
