RaceCapturePro2 ShiftLights
Revision as of 19:48, 19 December 2014 by Brentp (talk | contribs) (initial edit)
Sequential Shift light
One way to enable shift light is by using the PWM / Analog output channels to trigger a 3 + 1 shift light output. In this case, we used 3 of the outputs to control the 3 LED segments on the ShiftX Sequential Shift Light display, and the 4th output controls a focused Red LED that flashes at the top end of the RPM range.
  • Example Video:
Video
Script
Requirements
  • A working RPM signal connected to the first timer input channel on RaceCapture/Pro.
  • Shift light boards connected to PWM / Analog out 1 - 3; flash alert LED to the 4th output
3 stage + 1 sequential shift light
Input
Timer 0 - RPM
Tach Lights
0 - Green Light
1 - Yellow Light
2 - Red Light
3 - Flash alert
-- Globals --
LIGHTS = 4
LIGHT_VALS = {}
FREQUENCY_HZ = 10
-- Global Init --
setTickRate(FREQUENCY_HZ)
function toggleLight(index)
   LIGHT_VALS[index] = not LIGHT_VALS[index]
function lightOn(index)
   LIGHT_VALS[index] = true
function lightOff(index)
   LIGHT_VALS[index] = false
local lCount = 0
repeat
   lightOff(lCount)
   lCount = lCount + 1
until lCount >= LIGHTS
-- Script --
function updateLights()
   local l = 0
   repeat
      -- Convert our booleans to 1 (true) or 0 (false) --
      local val = LIGHT_VALS[l]
      local dc = 0
      if not val then
         dc = 100
      setPwmDutyCycle(l, dc)
      l = l + 1
   until l >= LIGHTS
function checkRpm()
   local rpm = getTimerRpm(0)
   if rpm < 3000 then
        lightOff(0)
        lightOff(1)
        lightOff(2)
        lightOff(3)
   elseif 3000 < rpm and rpm < 4500 then
        lightOn(0)
        lightOff(1)
        lightOff(2)
        lightOff(3)
   elseif 4500 < rpm and rpm < 5000 then
        lightOn(0)
        lightOn(1)
        lightOff(2)
        lightOff(3)
   elseif 5000 < rpm and rpm < 5500 then
        lightOn(0)
        lightOn(1)
        lightOn(2)
        lightOff(3)
   else
        toggleLight(3)
function controlLights()
   checkRpm()
   updateLights()
-- Start!
   controlLights()
