RaceCapturePro Downloads
Revision as of 19:43, 3 January 2015 by Brentp (talk | contribs) (→‎App: updated version)
RaceCapture/Pro MK2
App
Windows
RaceCapture App v1.2.2
Previous Versions
Mac OS X
Mac installer coming soon!
Linux
Packages coming soon!
Driver
App
Firmware
Previous Versions
How to update MK2 Firmware
Save your configuration
Alternative method
  • You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
RaceCapture/Pro MK1
Firmware
Previous Versions
RaceCapture App
  • Linux: currently supported (run from source code; installer coming soon)
  • Android: port scheduled
  • iOS: port scheduled
Windows
Linux
Race Analyzer Downloads
Windows XP/Vista/7/8
Latest
Previous Versions
Mac OS X
Linux
Release Notes
Release Notes
Sample Logfiles
Driver Downloads
Windows 8 Note
Windows XP/Vista/7/8 Drivers V2 For firmware version 1.2 and higher
Firmware Downloads
Latest
Previous Versions
Firmware Instructions
Release Notes
Release Notes
Bootloader Releases
bootloader_0.0.2.bin
bootloader_0.0.1.bin
Firmware update utility
