RaceCapturePro Downloads
Revision as of 19:51, 3 January 2015 by Brentp (talk | contribs) (→Firmware)
RaceCapture/Pro MK2
App
Windows
RaceCapture App v1.2.2
Previous Versions
Mac OS X
Mac installer coming soon!
Linux
Packages coming soon!
Driver
App
Firmware
Previous Versions
How to update MK2 Firmware
Save your configuration
Alternative method
  • You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
RaceCapture/Pro MK1
Firmware
The 2.7.6 firmware for MK1 is considered 'stable beta' - We feel it's much better quality than the previous 1.2.x firmware and RaceAnalyzer combination, but since it is the first V2 firmware and app release for MK1, we are officially calling it Beta.
Previous Versions
RaceCapture App
  • Linux: currently supported (run from source code; installer coming soon)
  • Android: port scheduled
  • iOS: port scheduled
Windows
Linux
Race Analyzer Downloads
Windows XP/Vista/7/8
Latest
Previous Versions
Mac OS X
Linux
Release Notes
Release Notes
Sample Logfiles
Driver Downloads
Windows 8 Note
Windows XP/Vista/7/8 Drivers V2 For firmware version 1.2 and higher
Firmware Downloads
Latest
Previous Versions
Firmware Instructions
Release Notes
Release Notes
Bootloader Releases
bootloader_0.0.2.bin
bootloader_0.0.1.bin
Firmware update utility
