CAN bus mappings by OEM ECU and aftermarket device
Megasquirt CAN ( MS2/MS3/MS3 Pro )
Installation instructions
- Baud Rate: 500K
- Values in big endian format
- Default base CAN id: 1520
| Megasquirt CAN
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
| RPM
1520
6
2
(B6 * 256) + B7
| IgnTiming
Degrees
1521
0
2
((B0 * 256) + B1) / 10
| AFR
AFR
1521
4
2
((B4 * 256) + B5) / 10
Legacy AFR1 (Deprecated on MS3) - to use AFR2 specify offset 6
| MAP
kPa
1522
2
2
((B2 * 256) + B3) / 10
| MAT
F
1522
4
2
| EngineTemp
F
1522
6
2
((B6 * 256) + B7) / 10
| TPS
1523
0
2
| EngineTemp
F
1522
6
2
| Knock
1524
0
2
Indication of knock input
| AFR
1551
0
1
B0 / 10
AFR for cylinder #1 (MS3+ compatible) - add 1 to offset for subsequent AFR inputs
BMW E46
| BMW E46 (including M3)
| Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
| TPS
809
6
1
(B6 / 255)
| EngineTemp
C
809
2
1
(B2 * 0.75) - 48.373
Convert to Farenheight: (temperatureC * 1.8) + 32
| OilTemp
C
1349
5
1
B5 - 48.373
| RPM
790
3-4
1
((B4 * 256) + B3) / 6.4
