CAN Bus database
Revision as of 19:14, 9 March 2015 by Brentp (talk | contribs) (added AIM smartycam integration)
CAN bus mappings by OEM ECU and aftermarket device
AIM Smarty CAM CAN protocol
Installation instructions
  • Baud Rate: 1MB (Configurable in Megasquirt)
  • Values in big endian format
AIM Smarty CAM protocol
Channel Units CAN Id Offset (bytes) Length (bytes) Multiplier Adder Notes
RPM RPM 1056 0 2 1 0
EngineTemp C 1056 6 2 0.1 0
OilTemp C 1057 4 2 0.1 0
OilPress Bar 1057 6 2 0.01 0
TPS % 1058 2 1 1 0
Fuel L 1070 0 1 1 0
Megasquirt CAN ( MS2/MS3/MS3 Pro )
Megasquirt CAN (Dashboard Mode)
Channel Units CAN Id Offset (bytes) Length (bytes) Conversion Notes
In development
Megasquirt CAN (standard mode)
RPM RPM 1520 6 2 (B6 * 256) + B7
IgnTiming Degrees 1521 0 2 ((B0 * 256) + B1) / 10
AFR AFR 1521 4 2 ((B4 * 256) + B5) / 10 Legacy AFR1 (Deprecated on MS3) - to use AFR2 specify offset 6
MAP kPa 1522 2 2 ((B2 * 256) + B3) / 10
MAT F 1522 4 2 ((B4 * 256) + B5) / 10
EngineTemp F 1522 6 2 ((B6 * 256) + B7) / 10
TPS % 1523 0 2 ((B0 * 256) + B1) / 10
Knock % 1524 0 2 ((B0 * 256) + B1) / 10 Indication of knock input
AFR % 1551 0 1 B0 / 10 AFR for cylinder #1 (MS3+ compatible) - add 1 to offset for subsequent AFR inputs
BMW E46
  • Baud Rate: 500K
  • Little Endian Format
BMW E46 (including M3)
TPS % 809 6 1 (B6 / 255)
EngineTemp C 809 2 1 (B2 * 0.75) - 48.373 Convert to Farenheight: (temperatureC * 1.8) + 32
OilTemp C 1349 5 1 B5 - 48.373 Convert to Farenheight: (temperatureC * 1.8) + 32
RPM 790 3-4 1 ((B4 * 256) + B3) / 6.4
Mini Cooper R53
  • Baud Rate: 500K
Mini Cooper R53
TPS % 809 6 1 (B6 / 254) * 100
MBE Systems 992
  • Baud Rate: ???
  • Little Endian format
MBE Systems 992 (Locked Caterham mode)
EngineTemp C? 814 0 1 B0 Need to verify scaling and temperature units
RPM RPM 814 1 2 (B2 * 256) + B1
TPS % 814 3 0 B0 / 5.0 Outputs as throttle voltage. assuming a 0-5v system, scale by 5v
OilPress PSI? 815 2 1 B2 Need to verify scaling and Pressure units
OilTemp C? 815 3 1 B3 Need to verify scaling and temperature units
