CAN bus mappings by OEM ECU and aftermarket device
AIM Smarty CAM CAN protocol
Installation instructions
- Baud Rate: 1MB (Configurable in Megasquirt)
- Values in little endian format
AIM Smarty CAM protocol
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Multiplier
Adder
Notes
1056
0
2
1
0
EngineTemp
C
1056
6
2
0.1
0
OilTemp
C
1057
4
2
0.1
0
OilPress
Bar
1057
6
2
0.01
0
TPS
1058
2
1
1
0
Fuel
L
1070
0
1
1
0
Megasquirt CAN ( MS2/MS3/MS3 Pro )
Megasquirt CAN (Dashboard Mode)
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
In development
Megasquirt CAN (standard mode)
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
1520
6
2
(B6 * 256) + B7
IgnTiming
Degrees
1521
0
2
((B0 * 256) + B1) / 10
AFR
AFR
1521
4
2
((B4 * 256) + B5) / 10
Legacy AFR1 (Deprecated on MS3) - to use AFR2 specify offset 6
MAP
kPa
1522
2
2
((B2 * 256) + B3) / 10
MAT
F
1522
4
2
EngineTemp
F
1522
6
2
((B6 * 256) + B7) / 10
TPS
1523
0
2
EngineTemp
F
1522
6
2
Knock
1524
0
2
Indication of knock input
AFR
1551
0
1
B0 / 10
AFR for cylinder #1 (MS3+ compatible) - add 1 to offset for subsequent AFR inputs
BMW E46
- Baud Rate: 500K
- Little Endian Format
BMW E46 (including M3)
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
TPS
809
6
1
(B6 / 255)
EngineTemp
C
809
2
1
(B2 * 0.75) - 48.373
Convert to Farenheight: (temperatureC * 1.8) + 32
OilTemp
C
1349
5
1
B5 - 48.373
790
3-4
1
((B4 * 256) + B3) / 6.4
Mini Cooper R53
- Baud Rate: 500K
Mini Cooper R53
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
TPS
809
6
1
(B6 / 254) * 100
EngineTemp
C
809
2
1
790
3-4
1
MBE Systems 992
- Baud Rate: ???
- Little Endian format
MBE Systems 992 (Locked Caterham mode)
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
EngineTemp
C?
814
0
1
B0
Need to verify scaling and temperature units
814
1
2
(B2 * 256) + B1
TPS
814
3
0
B0 / 5.0
Outputs as throttle voltage. assuming a 0-5v system, scale by 5v
OilPress
PSI?
815
2
1
B2
Need to verify scaling and Pressure units
OilTemp
C?
815
3
1
B3
