BMW E46 CAN
Things you'll need
  • Crimp tool
  • Wire cutter
  • Wire stripper
  • Philipps screwdriver
  • Multimeter
  • 22 gauge solid wire
  • Flashlight
  • Android tablet
  • An E46 ;)
Estimated Time
Step 1: CAN wires
  • Yellow/Brown = CAN- (low)
  • Yellow/Red = CAN+ (high)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Step 2: Power and ground wiring
Mk1 owners: do not wire in power or ground.
Locate power and ground wires
Splice power and ground wires
Step 3: Build CAN cable
Step 4: Configure RaceCapture/Pro
  • Rate is 500kb/s
  • Do not enable OBD-II channels.
coolantId = addChannel("EngineTemp", 10)
oilId = addChannel("OilTemp", 10)
throttleId = addChannel("TPS", 10)
brakeId = addChannel("Brake", 10)
setTickRate(30)
  repeat
    id, ext, data = rxCAN(0)
    if id == 809 then
      temperatureC = (data[2] - 48 ) * 0.692
      temperatureF = (temperatureC*1.8)+32
      setChannel(coolantId, temperatureF)
      throttle = data[6]/255
      setChannel(throttleId, throttle)
      brake = data[7]
      setChannel(brakeId, brake)
    if id == 1349 then
      temperatureC = data[5] - 48
      setChannel(oilId, temperatureF)
  until id == nil
Step 5: Test!
If you are still having issues post your problem on the forums here http://www.autosportlabs.org/viewforum.php?f=20&sid=88ccc8d4a459a907c2b8f951f6b3d103
CAN Channel Mapping
Additional resources
