BMW E46 CAN
Things you'll need
  • Crimp tool
  • Wire cutter
  • Wire stripper
  • Philipps screwdriver
  • Multimeter
  • 22 gauge solid wire
  • Flashlight
  • Android tablet
  • An E46 ;)
Estimated Time
CAN wires
  • Yellow/Brown = CAN- (low)
  • Yellow/Red = CAN+ (high)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Mk1 owners: do not wire in power or ground.
Locate power and ground wires
Splice power and ground wires
Connect CAN cable
Step 4: Configure RaceCapture/Pro
  • Rate is 500kb/s
  • Do not enable OBD-II channels.
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
be_mode = 0
function steerFilter(value)
 if value > 32768 - 1 then value = value - 32768 end
 return value
--Convert C to F
function toF(value)
 return value * 1.8 + 32
--E46 TPS, because 100% throttle actually returns 86%
function e46_tps(value)
 return value * 1.16
function rpmFilter(value)
 return value
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, data, <CAN offset>, <CAN length>, <multiplier>,
--                                   <adder>, [filter])
CAN_map = {
[809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, e46_tps) map_chan_le(tempId, data, 1, 1, 0.562, -48, toF) end,
[1349] = function(data) map_chan(oilTempId, data, 4, 1, 0.8117, -48, toF) end,
[790] = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
function map_chan_le(cid, data, offset, len, mult, add, filter)
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
 local cv = (value + add) * mult
    setChannel(cid, cv)
function map_chan_be(cid, data, offset, len, mult, add, filter)
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
    setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
setTickRate(tickRate)�
Test!
Real-Time Telemetry!
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to race-capture.com for monitoring engine, driver and suspension performance!
If you are still having issues post your problem on the forums here http://www.autosportlabs.org/viewforum.php?f=20&sid=88ccc8d4a459a907c2b8f951f6b3d103
CAN Channel Mapping
Additional resources
