Hondata KPro4
Revision as of 22:31, 14 July 2015 by Brentp (talk | contribs) (Created page with "The following script adapts the Hondata KPro4 CAN to RaceCapture/Pro Image:Hondata_KPro4.jpg <pre> --This example adopted to Hondata KPro4 CAN output --how frequently we ...")
--how frequently we poll for CAN messages, 30Hz is the max
tickRate = 30
--the CAN baud rate
CAN_baud = 250000
CAN_chan = 0
be_mode = 1
rpmId = addChannel("RPM", 10, 0, 0, 9000, "RPM")
vltId = addChannel("VLT", 10, 1, 0, 20, "volts")
iatId = addChannel("IAT", 1, 0, 0, 100, "C")
ectId = addChannel("ECT", 1, 0, 0, 150, "C")
mapId = addChannel("MAP", 10, 1, 0, 15, "PSI")
injId = addChannel("INJ", 10, 3, 0, 100, "ms")
ignId = addChannel("IGN", 10, 0, -20, 20, "D")
lmdId = addChannel("LMD", 10, 3, 0, 2, "lambda")
knkId = addChannel("KNK", 1, 0, 0, 15, "count")
camId = addChannel("CAM", 10, 0, -20, 20, "D")
--offset/length in bytes?
CAN_map = {
--did not bother logging gear speed and target cam angle
[1632] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(vltId, data, 5, 1, 0.1, 0) end,
[1633] = function(data) map_chan(iatId, data, 0, 2, 1, 0) map_chan(ectId, data, 2, 2, 1, 0) end,
[1634] = function(data) map_chan(tpsId, data, 0, 2, 1, 0) map_chan(mapId, data, 2, 2, 0.0145037738, 0) end,
[1635] = function(data) map_chan(injId, data, 0, 2, 0.001, 0) map_chan(ignId, data, 2, 2, 1, 0) end,
[1636] = function(data) map_chan(lmdId, data, 0, 2, 0.00003051757, 0) end,
[1637] = function(data) map_chan(knkId, data, 0, 2, 1, 0) end,
[1638] = function(data) map_chan(camId, data, 2, 2, 1, 0) end
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
