RaceCapturePro2 Hardware Install
Power Connection
Analog Inputs 1-7
- Input Impedance: 15K ohm
Active Sensors/Signals
Resistive sensor
Analog/Frequency Outputs 1 - 4
Frequency/Pulse Input 1 - 3
TACH SIGNAL NOTES
SD Card Slot
USB Port
LED Indicators
- Power LED
- LED1
- LED2
- LED3
Pushbutton
Communication Ports
- Port 1
Used for BT module
- Port 2
Serial I/O
Shock isolation mounting
The default accelerometer configuration assumes RaceCapture/Pro is mounted flat, right side up with the green terminal block pointed towards the front of the vehicle. Other orientations are supported by changing the settings in the Software. See the Operation Guide for more information.
