BMW E46 CAN
Revision as of 20:48, 10 February 2016 by Brentp (talk | contribs) (→Script)
Things you'll need
  • Crimp tool
  • Wire cutter
  • Wire stripper
  • Philipps screwdriver
  • Multimeter
  • 22 gauge solid wire
  • Flashlight
  • Android tablet
  • An E46 ;)
Estimated Time
CAN wires
  • Yellow/Red = CAN+ (high)
  • Yellow/Brown = CAN- (low)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Option #1: OBD-II port power
CAN High Yellow/Red Orange
Splice power and ground wires
CAN Bus connection
  • Orange: CAN1 High
  • Green/white: CAN1 Low
  • Brown: Power
  • Orange/white: Ground
Use the following diagram:
Configure RaceCapture/Pro
Quick Start E46 configuration
Download: E46 CAN starter configuration (right-click, save-as)
Manual Setup
  • Rate is 500kb/s
  • Do not enable OBD-II channels.
Script
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F")
oilTempId = addChannel("OilTemp", 1, 0, 0, 255, "F")
steerId = addChannel("Steering", 10, 0, -360, 360, "Deg.")
brakeId = addChannel("BrakeSw", 10, 0, 0, 1)
brakePressId = addChannel("Brake", 10, 0, 0, 255, "Bar")
clutchId = addChannel("Clutch", 10, 0, 0, 1)
lfWheelId = addChannel("LFWheelSpd", 10, 0, 0, 200, "MPH")
rfWheelId = addChannel("RFWheelSpd", 10, 0, 0, 200, "MPH")
lrWheelId = addChannel("LRWheelSpd", 10, 0, 0, 200, "MPH")
rrWheelId = addChannel("RRWheelSpd", 10, 0, 0, 200, "MPH")
gearTempId = addChannel("GearboxTmp", 10, 0, 0, 400, "F")
fuelId = addChannel("Fuel", 1, 0, 0, 100, "%")
extTempId = addChannel("ExtTemp", 1, 0, 0, 120,"F")
--Convert C to F
function toF(value)
 return value * 1.8 + 32
function e46_tps(value)
 return value + 0.0
function rpmFilter(value)
 return value
function brakeFilter(value)
 return bit.rshift(bit.band(value, 0x10), 4)
function clutchFilter(value)
 return bit.band(value, 0x01)
function processWheel(id, data, offset)
  --wheel speed is 13 bits long, little endian
  --low byte high byte
  --76543210 76543210
  --11111111 11111XXX
  local highByte = bit.band(data[offset + 2], 0x1F)
  local lowByte = data[offset + 1]
  local value = highByte * 256 + lowByte
  value = value * 0.0625
  --convert to MPH. comment to keep KPH
  value = value * 0.621371
  setChannel(id, value)
function processSteering(data)
    local steer = 0
    if data[2] > 127 then
    else
      steer = (data[2]*256)+data[1]
function fuelFilter(value)
  --adjust for 7 bit value
  value = bit.band(value, 0x7F)
  --convert liters to %. tank holds 62.83 liters
  return value / 0.6283
function extTempFilter(value)
  local temp = bit.band(value, 0x7F)
  if value > 127 then
    temp = -1 * temp
  temp = toF(temp)
  return temp
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>,
--                                   <adder>, [filter])
CAN_map = {
[496] = function(data) processWheel(lfWheelId, data, 0)
                       processWheel(rfWheelId, data, 2)
                       processWheel(lrWheelId, data, 4)
                       processWheel(rrWheelId, data, 6)
        end,
[339] = function(data) map_chan(brakeId, data, 0, 1, 1, 0, brakeFilter) end,
[504] = function(data) map_chan(brakePressId, data, 2, 1, 1, 0) end,
[809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, e46_tps)
                       map_chan(tempId, data, 1, 1, 0.75, -48, toF)
                       map_chan(clutchId, data, 3, 1, 1, 0, clutchFilter)
        end,
[1083] = function(data) map_chan(gearTempId, data, 0, 1, 1, -55, toF) end,
[790]  = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end,
[501]  = function (data) processSteering(data) end,
[1555] = function (data) map_chan(fuelId, data, 2, 1, 1, 0, fuelFilter) end,
[1557] = function (data) map_chan(extTempId, data, 3, 1, 1, 0, extTempFilter) end
    processCAN(CAN_chan)
function processCAN(chan)
    local msg = 0
    repeat
        local id, e, data = rxCAN(chan, 0)
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
        msg = msg + 1
    until id == nil or msg > 100
    if offset + len > #data then return end
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
 local cv = value * mult + add
    setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
Test!
Real-Time Telemetry
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to race-capture.com for monitoring engine, driver and suspension performance!
CAN Channel Mapping
Additional resources
