RaceCapturePro2 hardware guide
Quick Reference
Download a printable PDF
Power Connection
Analog Inputs 1-7
- Input Impedance: 1 megaohm
Active Sensors/Signals
Resistive sensor
Analog Calibration
- The default calibration value is 1.0 - you can adjust it up or down to fine tune to match your electrical system.
Analog/Frequency Outputs 1 - 4
- When configured for input, the channel accepts a 0-5v input (protected up to 400V).
- When configured for output, the channel provides an open-drain output that can drive 1A and is thermal / over-current protected with inductive load clamping.
Frequency/Pulse Input 1 - 3
TACH SIGNAL NOTES
CAN bus port
- See the quick reference guide for pinout
SD Card Slot
USB Port
LED Indicators
- Power LED
- GPS LED
- Logging LED
- Telemetry LED
Indicates telemetry activity.
- A slow flash interval indicates connection initialization
- A regular flash matching the highest logging rate (up to 10Hz) indicates connected and streaming
Pushbutton
- Note this may be overridden by any on-board scripts that may automatically start or stop logging.
Communication Ports
- Ext Telemetry / Bluetooth - Used for Bluetooth module
- Auxiliary port - used for integrating external systems / devices
- On-board Lua Scripting can be used to customize integrations with external devices
GPS port
- Tighten this to 3-5 inch/lbs. This connection should be snug.
- To prevent damage to the connector, do not over-tighten
Telemetry port
Physical Installation
- Dimensions: 5.3" (width) x 4.2" (height) x 1.2" (tall) / 135x110x31 mm(est)
- Mounting area: 5.5"(140mm) x 4"(102mm)
- Mounting fasteners: Dual mounting points on 5" (127mm) centers - 0.125"-0.25" (3-6mm) fastener
Shock isolation mounting
