RaceCapturePro Lua Scripting
Example Scripts and How-Tos
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
- returns:
- none
getButton()
- params
- none
- returns
PWM / Analog Output functions
- params
- returns
- none
setPwmClockFreq( frequency )
- params
- returns
- none
- params
- returns
- none
Timer / RPM Sensor Functions
getTimerRpm(channel)
- params
- channel: Timer channel 0 - 2
- returns: RPM value
getTimerPeriodMs(channel)
- params
- channel: Timer channel 0 - 3
- returns: millisecond value
getTimerFreq(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
Analog Sensor Functions
getAnalog(channel)
- params
- channel: Analog input channel 0 - 7
- Note: channel 7 is internally dedicated to battery voltage.
getImu(channel)
- params
- channel (0 - 2 for accelerometer, 3 for yaw gyro sensor)
- returns
getImuRaw(channel)
- params
- returns
- The raw accelerometer value
GPS Sensor Functions
getGpsPos()
- params
- none
- returns
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getGpsDist()
- params
- (none)
- returns
- The distance, in Miles
getGpsAltitude()
- Added: v2.9.0
- Parameters: None
- Returns: <altitude>
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getGpsSec()
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
getTimeDiff(time1, time2)
- params
- time1
- time2
- returns
getTimeSince(time)
- params
- time
- returns
CAN Bus functions
initCAN(channel, baud )
- params
- returns
- params
- returns
Example:
channel = 0
id = 1234
ext = 0
data = {11,22,33}
rxCAN(channel, [timeout] )
- params
- timeout (optional). read timeout in milliseconds. defaults to 100ms
- returns
Example:
- params
- returns
readOBD2( PID )
- params
- returns
Logger Control Functions
onTick()
- params:
- (none)
- returns:
- (none)
Example:
setTickRate(rate)
- params
- rate: The rate the onTick() function is called, in Hz. Max tick rate is 30Hz.
- returns
- (none)
startLogging()
Begins a logging session
- params
- (none)
- returns
- (none)
stopLogging()
- params
- (none)
- returns
- (none)
setLed( led, state )
- params
- led (1-3)
- state : 1 = on, 0 = off
- returns
- (none)
Serial Port Communications
Port mappings
0 = USB port
1 = GPS port
3 = Wireless / Bluetooth port
4 = Auxiliary port
- params
- returns
readCSer( port, [timeout])
- params
- returns
readSer( port, [timeout])
- params
- port: Serial port 0 - 4
writeCSer( port, data )
- params:
- returns:
(no return values)
writeSer( port, data )
- params
- returns:
(no return values)
flashLoggerCfg()
- params
- (none)
- returns
- (none)
setPwmClockFreq( freq )
- params
- returns
- (none)
getPwmClockFreq()
- params
- (none)
- returns
calibrateImuZero()
- params
- (none)
- returns
- (none)
Virtual Channels
available in firmware 2.0 Adds a virtual channel. This virtual channel remains in memory during runtime; it is not persisted in the configuration. Up to 30 virtual channels can be created.
- params
- returns
- params
Example:
id = addChannel("EGT", 1)
temp = temp * 1000
Time Info
getUptime()
- Returns
getDateTime()
Returns date and time info to the best of the systems ability. Only available after GPS lock has been established. Will return epoch time (Jan 1, 1970 00:00:000) if time is not available.
- Year
- Month
- Day
- Hour
- Second
- Millisecond
