BMW E36 Guide
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
In research
(Needs verification)
- 0 ohms empty
- ?? ohms 1/2 full
- 260 ohms full
Oil Pressure
