BMW E46 CAN
Things you'll need
- Crimp tool
- Wire cutter
- Wire stripper
- Philipps screwdriver
- Multimeter
- 22 gauge solid wire
- RJ 45 (Ethernet) cable, ~6ft
- Shrink tubing (optional, electrical tape will work too, but not look as nice)
- Posi-tap connectors (2) - Do *not* cut the CAN wires during this installation, use wire taps (Posi-taps work very well)
- Butt connectors (2) for 22 gauge wire
- Flashlight
- RaceCapture/Pro with Bluetooth
- Android tablet
- An E46 ;)
Estimated Time
CAN wires
- Yellow/Red = CAN+ (high)
- Yellow/Brown = CAN- (low)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Option #1: OBD-II port power
Connection | BMW | RaceCapture/Pro (RJ45 cable) |
+12v | Yellow-Red (OBD-II connector) | Brown |
Ground | Brown (OBD-II connector) | Orange/White |
CAN High | Yellow/Red | Orange |
CAN Low | Yellow/Brown | Green/White |
Splice power and ground wires
CAN Bus connection
- Orange: CAN1 High
- Green/white: CAN1 Low
- Brown: Power
- Orange/white: Ground
Use the following diagram:
Configure RaceCapture/Pro
Quick Start E46 configuration
Download: [File:RaceCapturePro_E46_starter_config.rcp] (right-click, save-as)
- Add your favorite race tracks for automatic detection
- Set your telemetry device id as provided by race-capture.com
Manual Setup
- Rate is 500kb/s
- Do not enable OBD-II channels.
Script
--This example configured for E46 CAN -- Automatically starts logging with engine 'on' (RPM triggered) --how frequently we poll for CAN messages tickRate = 30 --the CAN baud rate CAN_baud = 500000 --CAN channel to listen on. 0=first CAN channel, 1=second CAN_chan = 0 --add your virtual channels here --format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units]) tpsId = addChannel("TPS", 10, 0, 0, 100, "%") tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F") oilTempId = addChannel("OilTemp", 1, 0, 0, 255, "F") rpmId = addChannel("RPM", 10, 0, 0, 10000) steerId = addChannel("Steering", 10, 0, -360, 360, "Deg.") brakeId = addChannel("BrakeSw", 10, 0, 0, 1) brakePressId = addChannel("Brake", 10, 0, 0, 255, "Bar") clutchId = addChannel("Clutch", 10, 0, 0, 1) lfWheelId = addChannel("LFWheelSpd", 10, 0, 0, 200, "MPH") rfWheelId = addChannel("RFWheelSpd", 10, 0, 0, 200, "MPH") lrWheelId = addChannel("LRWheelSpd", 10, 0, 0, 200, "MPH") rrWheelId = addChannel("RRWheelSpd", 10, 0, 0, 200, "MPH") gearTempId = addChannel("GearboxTmp", 10, 0, 0, 400, "F") fuelId = addChannel("Fuel", 1, 0, 0, 100, "%") extTempId = addChannel("ExtTemp", 1, 0, 0, 120,"F") --Convert C to F function toF(value) return value * 1.8 + 32 end --E46 TPS, correct your throttle here for true 100% function e46_tps(value) return value + 0.0 end --only start logging / telemetry if engine is running function rpmFilter(value) if value > 500 then startLogging() else stopLogging() end return value end function brakeFilter(value) return bit.rshift(bit.band(value, 0x10), 4) end function clutchFilter(value) return bit.band(value, 0x01) end function processWheel(id, data, offset) --wheel speed is 13 bits long, little endian --low byte high byte --76543210 76543210 --11111111 11111XXX local highByte = bit.band(data[offset + 2], 0x1F) local lowByte = data[offset + 1] local value = highByte * 256 + lowByte value = value * 0.0625 --convert to MPH. comment to keep KPH value = value * 0.621371 setChannel(id, value) end function processSteering(data) local steer = 0 if data[2] > 127 then steer = -1*(((data[2]-128)*256)+data[1]) else steer = (data[2]*256)+data[1] end setChannel(steerId, (steer*0.045)) end function fuelFilter(value) --adjust for 7 bit value value = bit.band(value, 0x7F) --convert liters to %. tank holds 62.83 liters return value / 0.6283 end function extTempFilter(value) local temp = bit.band(value, 0x7F) if value > 127 then temp = -1 * temp end temp = toF(temp) return temp end ---------------------------------------- --customize here for CAN channel mapping --format is: --[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>, -- <adder>, [filter]) ---------------------------------------- CAN_map = { [496] = function(data) processWheel(lfWheelId, data, 0) processWheel(rfWheelId, data, 2) processWheel(lrWheelId, data, 4) processWheel(rrWheelId, data, 6) end, [339] = function(data) map_chan(brakeId, data, 0, 1, 1, 0, brakeFilter) end, [504] = function(data) map_chan(brakePressId, data, 2, 1, 1, 0) end, [809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, e46_tps) map_chan(tempId, data, 1, 1, 0.75, -48, toF) map_chan(clutchId, data, 3, 1, 1, 0, clutchFilter) end, [1349] = function(data) map_chan(oilTempId, data, 4, 1, 1, -48, toF) end, [1083] = function(data) map_chan(gearTempId, data, 0, 1, 1, -55, toF) end, [790] = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end, [501] = function (data) processSteering(data) end, [1555] = function (data) map_chan(fuelId, data, 2, 1, 1, 0, fuelFilter) end, [1557] = function (data) map_chan(extTempId, data, 3, 1, 1, 0, extTempFilter) end } function onTick() processCAN(CAN_chan) end --===========do not edit below=========== function processCAN(chan) local msg = 0 repeat local id, e, data = rxCAN(chan, 0) if id ~= nil then local map = CAN_map[id] if map ~= nil then map(data) end end msg = msg + 1 until id == nil or msg > 100 end --Map CAN channel, little endian format function map_chan(cid, data, offset, len, mult, add, filter) if offset + len > #data then return end offset = offset + 1 local value = 0 local shift = 1 while len > 0 do value = value + (data[offset] * shift) shift = shift * 256 offset = offset + 1 len = len - 1 end local cv = value * mult + add if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end initCAN(CAN_chan, CAN_baud) setTickRate(tickRate)
Test!
Real-Time Telemetry
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to race-capture.com for monitoring engine, driver and suspension performance!
CAN Channel Mapping
Additional resources
- http://aimsportsystems.com.au/download/ecu/stock/bmw/BMW_Mini_100_eng.pdf - AIM docs for e46 M3 CAN codes
- http://www.diyelectriccar.com/forums/showthread.php/my-can-bus-gauge-solution-bmw-84882.html
- http://www.beisansystems.com/misc/SEIMENS_MS_420_ENGINE_CONTROL_SYSTEM.pdf
- http://www.bmwtech.ru/pdf/e46/ST034/2%20Driver%20Information%20Internet-1.pdf
- http://www.gadgetgangster.com/news/54-new-projects/556-the-car-kracker.html
- http://www.reslers.de/IBUS/index.html
- http://www.bimmerforums.com/forum/showthread.php?1887229-E46-Can-bus-project
- http://forum.e46fanatics.com/showpost.php?p=15754605&postcount=5
