MJLJ V3 Operation Guide
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
- Does the MJLJ have power, and connected to the computer with a standard serial cable or compatible USB-Serial adapter?
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
The load gauge shows either KPa or TPS %, depending on your Controller's configuration and Configuration software setting. For MAP sensor based MJLJ's the scale can be further adjusted to show 0-103 KPa for normally aspirated engines. With forced induction applications the gauge can be set to show the full 0-255KPa range supported by the on-board MAP sensor.
. The current ignition configuration will be read from the MJLJ and displayed in the grid.
Ignition Map
Editing Ignition Map
Adjusting ignition advance
- Changing single value
- Changing multiple cells
- Ignition Advance range: Allowable ignition advance range is 0 to 59 degrees BTDC.
Adjusting Load / RPM Bins
- Ctrl-B in the main window
Controller Options
Engine Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
Shift Light
Rev Limit
After editing the ignition map or controller options, you may write the changes to the controller. To do this, click the Write Ignition Configuration toolbar icon
to write your changes to the controller.
Important Note: Writing the ignition configuration only updates the Controller's RAM. If changes are not persisted to the controller's Flash memory, the changes will be lost if the controller loses power (e.g. ignition key turned to 'off') This behavior is by design. Persisting the data to flash requires a significant amount of time and momentarily pauses the controller's operation while the flash memory is written.
Commit to Flash
To make the changes permanent in the Controller's flash memory, Click the 'Commit configuration to Flash' toolbar icon
. The controller will write the configuration to flash memory, and changes will be preserved after the controller loses power.
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Enabling Switchable Ignition Configurations
Enable hardware switch
- No Action: The software only alerts you of the change.
- Prompt to read configuration: The software prompts you to read the Ignition Configuration the controller was just switched to.
- Auto-Read configuration: The software automatically reads the Ignition Configuration the controller was just switched to, discarding any in-progress changes made in the software.
Important Usage Notes
Charting / Runtime view
Tuning Perspective
The configuration software offers a 3D interactive tuner which makes it easy to interactively tune the ignition map and Load / RPM bins while the engine is running.
In this view you will see a contour plot of the ignition map, with the ignition advance as the elevation of the surface. 'Hotter' colors indicate more advance, and 'cooler' colors indicate less.
Editing the Ignition Map
- Navigation: Use the arrow keys to move your editing point around the Ignition Map.
- Increase/Decrease advance: To increase advance at the editing point, hold down the ctrl-key and press the up arrow key. Conversely, to decrease the ignition advance, hold down the ctrl-key and press the down arrow.
- Modify Load/RPM bins: You can increase/decrease the selected RPM bin by pressing Alt-left arrow / Alt-right arrow. Correspondingly, the selected Load bin can be modified by pressing Alt-up arrow / Alt-down arrow.
Hot Keys
- Lock editing with runtime: Pressing 'L' on the keyboard toggles locking the editing point (yellow ball) with the runtime point(red ball), making it easier to edit the map in the region where the engine is running.
- Enable real-time config update: Pressing 'U' on the keyboard toggles real-time updating of the edited ignition point. The values are stored in the Controller's RAM, but not persisted to flash.
