RaceCapture-Track
Revision as of 05:43, 16 November 2016 by Brentp (talk | contribs) (→‎Telemetry)
Start it up
Plug it in
Download the app
Access the system status pages through the top left menu. The system status offers information on GPS status, current WiFi state and more. You can also get a copy of the RaceCapture application log for diagnostics. RaceCapture status page.png
Navigating dashboard screens
Setup Mode
Telemetry
Podium.png To enable real-time telemetry, enter the device ID provided by your Podium account
Logs
Analysis Mode
RaceCapture will automatically record your session in the background while in dashboard mode. To view the data, enter the Analysis mode and load an existing session. The session will be automatically named with the track or with a timestamp.
Navigating data
Selecting Time vs Distance
Applying Decals
